Capturing NamedView without affecting UI
Hi all,
What’s the best way to capture (any) named view to a bitmap without relying on or affecting the current state of the UI? I can use the (deprecated) NamedViews.Restore() method, but then how do I switch the active view back to its original state?
The solution can’t leave a footprint in the doc :slight_smile:
Thanks!
Jon
Hi @Jon,
Not all of the NamedViewTable.Restore methods are deprecated.
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_DocObjects_Tables_NamedViewTable_Restore.htm
Try this:
1.) In the view you want to capture, save a temporary named view
2.) Restore your named view
3.) Capture the view
4.) Restore your temporary named view
5.) Delete your temporary named view
– Dale
Ah gotcha. That’ll work, thanks Dale!
