i want to 3D print screw container and made 2 centimeter helix and draw screws teeth but if i use sweep 1 command program can’t make it right the teeths don’t fit eachother. Can someone help me to draw inside and outside of threads ?
Upload a .3dm file with the geometry. You can drag the file to where you type a post, or click on the vertical arrow icon above where you type a post.
case screw cap.3dm (1.7 MB)
here is the files, i made the inside but outside piece dont fit what shoul i do about that
(https://www.youtube.com/watch?v=Tdc40v84G-A&t=694s) i watch this video and make everything same but if i choose roadlike option curves corrupting.
if you align your curves well, I think it should work:
is this what you were after?
case screw cap-sg.3dm (1.1 MB)
How can i open that file cause now im using rhino 7 ?
@anneniyedim the file you sent was made in a pirated version of Rhino. But I also see you have a Rhino 8 evaluation in use.
FWIW, I think I’d use RailRevolve here, with just one thread profile, the helix and the two points.
