There is a dashed line in my document that I can’t delete. I’ve disabled selection filter, there are no blocks, grasshopper isn’t running…
Any help is appreciated. Rhino 7, Windows.
dashedline.3dm (4.4 MB)
Hello- there is an extrusion object in that location, hidden, if the file you sent. No line that I can see.
Thanks for checking it. This is weird, I’ve tried on both Rhino 7 and Rhino 7 WIP. Any tips on how to find or select this hidden extrusion? I ran this and also reset the defaults on Wireframe mode in case there is some kind of display issue:
Command: Show
Showing one hidden object.
Command: Z
Command: '_Zoom
Drag a window to zoom ( All Dynamic Extents Factor In Out Selected Target 1To1 ): e
Unable to zoom - no objects are visible.
Hello- can you please run SystemInfo in Rhino and copy/paste the results here?
Rhino 7 SR8 2021-6-17 (Rhino 7, 7.8.21168.01001, Git hash:master @ 401162001ce142638467ff15f97e7bc9e02b017a)
License type: Commercial, build 2021-06-17
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display and OpenGL: NVIDIA Quadro P4200 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 4-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 466.11
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 4-7-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-12-2021
Driver Version: 27.21.14.6611
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Osprey (ae17e3af-8d7f-4e53-96dd-66dea33b4aad)\2020.3.30.1120\Osprey.rhp “Osprey”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.5.11.0\bullant.rhp “bullant” 1.5.11.0
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RhinoFileVersion\7.0.7703\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7703.19539
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21168.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21168.1001
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\ray\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hello - can you please try disabling these plug-ins in Options > Plug-ins page and then close and reopen Rhino - if the problem is gone, re-enable and load these one by one until you see which, if any, is causing the problem.
Thanks for the help Pascal!
Unfortunately ClippingBox was causing the issue, too bad because I like that plugin.
I was having the exact same issue: extrusion objects displaying as dashed lines, couldn’t select them, etc. Aaaand I also have the Clipping Box plug-in and disabling it (and restarting Rhino) fixed the issue.
