I’ve created a projec which for some reason says “unknown command” when I input a value into a movement or offset direction.
Something must be off with the units, but I can’t see what, as I have another project which works fine and seems to have the same unit settings. Must be something simple I’m missing.
After closing the problem project and opening it again, the behaviour is back to normal. But at one point I had the problem project and the nonproblem project open at the same time and it worked on the one but not the other.
Steps for issue: (n" is move distance constraint, commands are on command line)
LMB object > Move > Enter > LMB drag > <<n">> Enter = “unknown command ’ n” ’
Same for offset
LMB line > offset > Enter > (D > or) <<n">> = “unknown command ’ n” ’
It seems that it was a semi-crash of some kind where distance inputs are concerned.
