Can't force Reducemesh to follow edges that created original mesh
I have a sweep2 resultant surface that I convert to a mesh
I want to reduce and triangulate that mesh.. .so I reduceMESH, but I can’t get it to match the curves…When I lock mesh points that correspond to the original curve’s control points, It gets ALMOST there… but it ends up missing a curve edge or two.
i’ve also tried to match the number of control points (note the original curves are 10 and 13, but the 2nd mesh I have inserted control points and matched them for the reduceMESH command)
The bottom Polysurface is the result that I am going for… (it’s 21 surfaces)
