Can't customize "default" tools
Hi. I am still unable to drag tools into the popup palette. The palette is visible but does not become active by clicking in the menu bar. Any thoughts? Thank you.
Hello.
If you are trying to modify/create/populate your popup menu, you need to go to:
  • Rhinoceros tab
  • Preferences
  • Commands
  • Customize: Note that the default Tool Palette Set is read only. If you click in the top right, you can duplicate and create your own tool set. You can switch back n’ forth through that menu.
  • In the Primary Palettes list you should see Popup, click on that.
  • Now you can add tools: Drag from the list below, etc.
Is that helpful?
Hello! Yes that works! Thank you for taking the time to clarify that for me!
