Hi! This ShapeInBrep is still in red, and the alarm recalls that there is an open Brep, however, when I test the brep, they are all closed. Any idea what might be going on?
Thank you!
shape in brep.gh (35.5 KB)
Thank you!
I take it back - I see why youâre using the unionâŠand even if you werenât I suppose the component should still workâŠ
But itâs faulty:
no naked edges found when baked, capping doesnât work, and boolean union leaves it âopenâ in grasshopperâŠis this a bug to track @dale ?
@ffeldsberg, @René_Corella, the second item in the list reports as a closed non-manifold polysurface.
â Dale
Hi @dale ! Thank you very much for your time, but what does it mean?
Hi @dale, what would you say is the best way to solve the brep that canât be closed in GH and not in rhino?
