I was working with a Rhino6 model, and suddenly I cannot select any surfaces. I can select points and curves just fine. I’ve tried the Unlock command, and it says no objects are locked. When I go to the Edit menu and select all objects, points and curves are selected, but no surfaces. A left window drag picks points and curves but no surfaces.
If I bring up another file, I can select surfaces in it, and when I close the problem file and reopen it, the issue remains. So it is associated with that file somehow. Of course, I’ve also tried shutting down Rhino completely and reloading it - no joy.
Any ideas as to what is going on and how to fix it?
Edit: Here’s what an audit of the file shows - note no locked or hidden objects:
Document Manifest:
Texture Mapping: 0 active, 1 system.
Material: 0 active, 2 system.
Line Pattern: 6 active, 3 system.
Layer: 12 active, 1 system.
Group: none.
TextStyle: none.
Annotation Style: 1 active, 7 system.
Light: none.
Hatch Pattern: 0 active, 9 system.
Block: 17 active.
Model Geometry: 359 active.
Total: 395 model components. 23 system components.
Audit Summary:
Table tally:
12 layers
17 instance definitions
1 annotation styles
0 fonts
6 linetypes
Object tally:
294 normal objects
0 locked objects
0 hidden objects
0 deleted objects (in undo buffer)
65 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
No errors.
