Cannot Rotate Dimension Text
Hi Mary,
dimensions are aligned to viewing direction 1 until around 80 degrees (dim D, C) and than it flips the text to a correct side (A, B). I think it should flip the alignment right after 45 degrees. Then you rotate your drawing and see it from thedirection 2. So from my point of view, this is the main issue for dimensions text aligment.
That special option I mentioned could be a definition of a treshold for text alignment depending on rotation of a dim. Now its 0-80 degrees, then flip. Easier way could be an option to flip alignment of the text in properties of a current dim. Sorry for my english, hope you understand.
