This has been an on-going issuefor years, which I can normally get around by opening, closing, cleaning, compiling the project until the RenderContentUserControlCollapsibleSection form will finally open. But now I am stuck and I absolutely cannot open my form in Visual Studio. The project compiles without error.
namespace PhysicalcSoftware.OctaneRender.RhinoPlugin
[System.Runtime.InteropServices.Guid("25DA894E-91E4-4866-8426-47662116AC45")]
public partial class OctaneMaterialTreeControl : RhinoWindows.Controls.RenderContentUserControlCollapsibleSection
{ // etc
On reading through all the posts in that thread, and other threads, this seems to be an issue in RhinoCommon, in that RenderContentUserControlCollapsibleSection does not have TypeDescriptionProvider.
I have tried the hacky workaround (#if DEBUG solution described above) but adding a middle class as follows:
public class NonAbstractRenderContentUserControlCollapsibleSection : RenderContentUserControlCollapsibleSection
protected NonAbstractRenderContentUserControlCollapsibleSection() { }
public override LocalizeStringPair Caption => throw new NotImplementedException();
public override int SectionHeight => throw new NotImplementedException();
But this does not work. If I open the original form (which is not derived from the above class), I get:
Is there any chance there is a workaround for this please? I have an urgent need to edit the form (I need to add an image to an imagelist attached to the form).
1.) Build your plug-in.
2.) Go to the output folder and make a copy of your .RHP and rename the copy to .DLL
3.) Try opening your form in the designer.
From further reading, it looks like the full solution would be to fix up RenderContentUserControlCollapsibleSection so it includes a TypeDescriptionProvider as described at https://wonkitect.wordpress.com/2008/06/20/using-visual-studio-whidbey-to-design-abstract-forms/. Having RenderContentUserControlCollapsibleSection abstract is going to cause issues with Visual Studio. I am now in a situation where I cannot make an important change to my form, and completely stuck
Sorry to hassle McNeel on this, but I still cannot open my form, and need to release a new version of the plugin. Is there a solution to this issue please?
The fix (per now untested) is in the current internal builds and will thus be in the next public build - which, if all goes well, will be released next Tuesday / Wednesday.
