hello everyone,
very simple question
I cannot draw anything on surface, whenever Im trying to draw on perspective view port its not drawing on surface, please help…
and even im not able to get reference line while drawing smtng over surface
In Rhino, similar to many other cad applications you generally draw on a construction plane (the grid)
I’m not a modeling expert, others can chime in but you have a few options if you want to draw on the top surface of the extrusion you’re showing:
CPlane command and click one of the points on the top of the extrusion. (you need to turn on end OSnaps)AutoAlignCPlane and ctrl+shift select the surface. This will temporarily move the CPlane to the surface and you can draw on itSketch command with OnSurface optionOSnaps
