We are trying to link floor plans of a building into other files (rcp’s, electrical plans, mechanical plans, etc.) - similar to xref in AutoCAD.
We need to change some linetypes of the linked floor plan within the file it is being linked into but without changing it in the base file (as it is linked elsewhere) - for example, we need a soffit line to show hidden on the floor-plan but solid on the rcp where it is being linked into.
But, we get an error “Cannot Change Linetype of Referenced Layers” - this shows for both inserted files and files linked via work-sharing.
Is this typical for Rhino3D and is there a work-around? It looks like we can change all of the other layer options (print color, print width, etc.) but just Linetype appears to be an issue.
Thank you,
Austin
