Hello everyone, I have a problem with the Rhino 7 software while snapping during my project. The hover color and text color look dark, so I cannot read the text. For instance, “midpoint”, “end” etc. the words are written dark and these have a dark background as in the image. I could not find any solution to repair that trouble. Please help me. I am using a Mac.
Hi Omer - please run the _SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17002, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Educational, build 2022-01-10
License details: Stand-Alone
Apple macOS Version 12.4 (Build 21F79) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,1
Language: tr-TR (MacOS default)
AMD Radeon Pro 5300M OpenGL Engine (OpenGL ver:4.1 ATI-4.8.54)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: AMD Radeon Pro 5300M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
Logitech: USB Receiver
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.techsmith.TACC (1.0.3) 851BEDD1-1D12-3756-A948-978610078DEF
com.parallels.kext.usbconnect (18.0.1 53056) C32772B0-9768-3CE5-A2FB-81FF039115A3
com.parallels.kext.vnic (18.0.1 53056) 64382395-9D35-36AF-8E52-010BABC241AD
com.parallels.kext.hypervisor (18.0.1 53056) 54197F49-5188-3715-88CA-218710AB0D43
com.parallels.kext.netbridge (18.0.1 53056) 5E5C9215-D620-3FFD-9878-908B44FD0F9C
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/omerkesgin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.2/libSubstanceImporter.dylib
/Users/omerkesgin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.2/libsubstance_ogl3_blend.1.dylib
/Users/omerkesgin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.2/libsubstance_linker.1.dylib
/Users/omerkesgin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.2/SubstanceImporter.rhp "SubstanceImporter" 2.0.2.0
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp "Export_FBX" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp "Displacement" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp "AutoCAD file export : export_ACAD" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 7.14.22010.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 7.14.22010.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 7.14.22010.17002
Hi @Ömer_Kesgin, pls update your Rhino to the latest SR (currently 25) and see if this resolves your issue.
