Can we reverse back to a previous version installed on the mac rhino
Is there a way we reverse an upgrade, Im a month away from graduating and was accustomed on working with the renderer that was installed there. is there anyone that can help me with installing the old file again ?
thank you
You don’t need to revert. See the Changes section of this post. Restart Rhino after running the command.
omg ty
Just one little issue, none of the materials under the objects are editable
If these are Toucan materials, use the command TestShowToucan > enable Toucan > close all open Rhinos and then restart Rhino. At this point you can change the renderer in the Render drop down menu to Toucan. Toucan will not be in the release version so don’t use it going forward.
Thank Brian Im trying new things . Did you guys put out a tutorial on Rhino render and how the lighting and general settings work?
Thanks!
Not yet no, I plan to do some tutorials on using Rhino Render on the Mac but I’m waiting on a few more small tweaks before doing so.
