Meaning, select all layers that want to be merged, and move all objects to one single layer. There could be an option to create a new layer or select an existing one.
Would be quite useful.
Hello- I imagine this could be scripted, itās probably been done, but Iāll have a poke at it. It could handle locked and hidden objects that way as well.
I have one here I made for someone quite awhile back⦠See if it does what you want.
MergeLayers.py (1.0 KB)
Hey Pascal, thank you. Can I be a little picky? I think it would actually be more useful to have an option to merge āall identically named layers into a new one of that nameā. Including all sublayers too.
So for instance if you have layers:
Blue House
.indows
.doors
.roof
Red House
.windows
.doors
.roof
Scrip would create
windows_unique.
doors_unique
roof_unique.
And put all objects in those.
Hello - would you expect the orignal layers to be deleted?
Hmm, yes, but I can run Purge after so not really required.
Well, poking around I found an existing Mergelayers script - prolly about the same as @Helvetosaur 's, maybe I even stole it, but for the sake of variety, here you go -
MergeLayers.py (1.2 KB)
The other one should also be possible.
I donāt know if this is it but maybe -
MergeIdenticallyNamedLayers.py (1.4 KB)
Testing is guaranteed cursory.
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
If merging layers is a goal of this post please see my other post
