Can’t print PDFs
It is already 8.5 and i cant print my pdfs…
this is how it looks in vector using Rhino PDF driver:
hatches are completely botched!
there are many bugs still:
-you cannot click on text of leader or dimension in layout space (it wont get selected)
-you cannot doubleclick on gumball to move it when working with texts because text is edited rather than gumball is relocated
-hatches orientations when retyped with multiple does not work properly
-block instances scales are read incorectly
-i have no energy to deal with this …
Hi Juan, please send me this file and I will try to repeat this bug. If I can repeat it, I should be able to fix it pretty quick.
Thanks,
-Steve
Hi @Juan_Gallo thank you for the file. I can repeat the bug and am working on a fix now. It is a far from origin with hatches issue that I wasn’t accounting for. This will be fixed in next week’s 8.5 release candidate. If you want a build with this fix before next week, let me know and I’ll send you a link.
RH-80436 is fixed in Rhino 8 Service Release 5 Release Candidate
i appreciate your promptness but please make yourselves a checklist for future to check if function works with blocks and far from oriigin… those are 2 most frequent reasons why something does not work properly.
thanks :smiley:
I wish those were the only frequent sources of bugs :smiley:
it absolutely is not fixed. guys olease when you claim something is fixed you better check if it is actually true…
this drunken hatches are definitely not as they should look like.
Rhino 8 SR5 2024-2-20 Rhino 8, 8.5.24051.15001
That image does not look like the file that you sent me. There must be some subtle difference. Can you send me this model as well so I can try and repeat this issue?
Thanks,
-Steve
This will be fixed in the next 8.5 release candidate
