Hi all,
Is there a way to vary the size of the dimension and the model changes size accordingly, without using Grasshopper?
Thanks!!
Hi all,
Thanks!!
depending on the model you can use Ctrl+Shift to select surfaces or edges of a model and change their position or size or orientation etc.
DiegoKrause,
But can I enter a dimension number say it was originally 30cm and I want to change to 50cm, would the model size change as well?
Thanks
DiegoKrause,
Wow thank you, I have no idea ctrl, shift, alt can do so many things! Thanks for the video.
