Hi folks,
let’s see if I can explain myself…
I have a Python package that I have been using with Dynamo in Revit. It has several modules and it includes all necessary imports from the Revit API.
Recently I ported this package to Grasshopper to be used in Rhino.Inside and I found that I could run it with no modifications provided I had run it once already in Dynamo in the same session.
However, If I try to run it in Grasshopper WITHOUT opening Dynamo first it will fail with an ImportError because I’m using imports that belong to Dynamo and not to Rhino / Grasshopper.
For example, the active document variable has to be called differently depending on the scripts host:
In Dynamo: doc = DocumentManager.Instance.CurrentDBDocument
In Grasshopper: doc = Revit.ActiveDBDocument
I’m guessing that when I load the modules in Dynamo they are cached in IronPython and when the Rhino.Inside session starts thay are all there and I don’t get any errors.
This is black magic to me at this stage.
So, to sum it all up: what would be the best way for my script to check it is running in Dynamo or Grass and then do the imports accordingly?
Best to all
ps.- when dealing with RevitPythonShell or Dynamo I usually use a try / except block like so:
try:
# RPS
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
app = __revit__.Application
uiapp = __revit__
except NameError as ex:
uiapp = DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
