Hi
V5
Just thinking of photoshop actions, where one can hit record and perform a few commands then hit stop.
open next image, play the recording and the same commands are applied.
e.g resize jpg, convert to greyscale, apply sharpness, save image to another folder as q8 then close image.
Hit play and iot does this to the next image selected on screen, anf the next one if you hit play, etc etc.
You can even batch apply and it will perform this on all images in a certain folder.
I would like that in Rhino.
e.g. I select a curve, then hit record, run commands divide, then ctrl F (last created) then PlaneThroughPt then delete the selected items (the points)…hit stop.
select my next curve, hit play and it does this again.
is it possible ?
Steve
