The double click for moving the gumball handles or the gumball does not work for SubD objects.
To clarify, it works on SubD edges and vertices but not when complete objects are selected. Is there any way to move the scale handles it that mode?
I could not reproduce that here. Does it happen as well in a new file with a simple SubD Box?
If so, can you check if the problem persist in Safe Mode?
Hi John -
I’m not seeing that here. Please run the Rhino SystemInfo
command and copy-paste the result here.
Hi Wim, it works fine here too without Drakon plugin loaded. Thanks for checking.
