Can I set the default animation TargetFolder?
Is there a way to set the default animation TargetFolder for recording an animation?
Hi Mitch - it looks like not - that would be a good thing, I’ll get it on the pile.
You can make a macro for RecordAnimation that has the folder specified, in the meantime.
! _RecordAnimation _TargetFolder "C:\Users\pgola\OneDrive\Desktop\Junk\Animation"
RH-79386 Animation: Set a default target folder
I’d also appreciate if the target folder could be set somewhere in the settings.
It always reverts to the default. A per file sticky target folder would be nice too.
The file explorer already remembers the previous folder so that should not be so difficult to implement.
Thanks, added to the pile.
RH-79386 is fixed in Rhino 8 Service Release 14
You actually can indeed. Just check and click on the file route on your command bar, after you hit the RECORD ANIMATION button
