Trying to do animation [for the first time]
target folder … first you see a Windows D [drive I guess]. then it actually is looking for somewhere in Rhino 4
I tried to put it on desktop , got that strange error massage.
it runs the animation, but doesn’t save it any where [no D drive and no Rhino 4 here]
@Akash Thanks for reporting this. I noticed the error last week too and it was fixed in RH-53223 Animation: MACFAIL hit while trying to do simple Turntable. You should see that fix in the next RhinoBETA.
As for the D: drive letter issue, that I cannot reproduce. (I have no idea how @nathanletwory can.) I would be curious to hear how you are able to.
If you click on the box D: it is possible to delete the content, then insert for example “documents” at which point a window will open where the path is indicated. I believe there is something strange here.
thank you Dan
I’m now able to use the turntable animation.
a few points that I can see: 1) the rhino 4. D drive default path is still there. 2) the path window is very small uncomfortable to use, and looks outdated [rhino 4 look]. would be nice to have it open as a dropdown where we can see the whole path. 3) I can not find a setting to control the frame speed! the transition between frames is currently too fast for my purpose of showing an item of jewellery, I need it to revolve slowly and gently. 3a). so I can raise the number of frames and it goes slower, but this results in a very large number of images and is too large to use in a website. 3b) a speed control slider, + a fade in fade out smooth transition affect option, will make it a better tool, AFAICS.
thanks a lot
Akash
I was finally able to reproduce this one, but it required resetting all my preferences to the factory defaults. Once you have set a new path for this, it should stick though. I logged this in:
RH-53429 RecordAnimation: Initial folder is Windows-specific.
