If I draw 10mm by 10mm square (area will be 100mm^2) and then, is there any way I can scale them to 1500mm^2? do I have to calculate sqrt or any scaling command can work for that?
Hello- you can use the Scale
or Scale2d
command and after setting the base point, type
sqrt(1500)/10
, plus Enter, at the command line as the scale factor.
Thank you so much! it worked!
