with the help of a really nice youtube tutorial I created a pattern. Towards the end of the definition the pattern is transformed into a surface and then extruded.
However, for my purposes I would like to leave the pattern as curves to use other outlines curves as cutting curves. I would place my outline curve over the pattern (while it is still curves and not made into a surface) and then cut the pattern leaving only what is inside the outline, deleting what is outside.
Can I cut curves with curves?
I have been able to cut the pattern when I first transform it into a surface and then cut it with “surface split” where my outline curve cuts the pattern surface.
But if I could cut the pattern while it is still curves, I would prefer that.
Thank you for your help.
2021_11_27_CuttingPatternWithCurve.3dm (1.4 MB)
2021_11_27_CuttingPatternWithCurve.gh (22.6 KB)
