For 3 day’s I am trying to create a object with bool difference. can anyone help?
Test bool.3dm (2.0 MB)
Leoppold, Thanks. Moving the object just 0.1mm was enough. The red triangle is already a newly created oversized object. The original triangle is not in this file.
The problem with your red objects is that they have a bunch of zero width surfaces that are right at the intersection of the red and the black objects. Rhino should identify the red objects as BadObjects then you would know they are Bad..
That’s a Rhino bug, but don’t hold your breath nobody at McNeel cares. .
If you want to understand how Booleans work and why they fail, the best way to learn is to not use them. If you learn how to do this yourself with the surface tools you will not be mystified when booleans fail.
The red objects are designed to fail. The enclosed file shows how to model this so that it doesn’t fail.
Test boolX.3dm (1.2 MB)
To make this into one closed solid just select the black part and run Split command (use the cyan parts as cutting objects). After the split operation de-select the outer part of the black and hit delete. Then select the black and the cyan parts and run the Join command.
Hi Jim, thanks for explaining the cause of the problem. Unfortunately, your file was created with V9 and I cannot open it in V6. That’s a pitty. I do understand that a surface with a width of 0 causes problems. I will try to figure out exactly what you mean. Thanks again.
Oh, sorry. I usually try to save as a legacy file, but I was in a hurry.
Here is the same file in V6 format.
I should have mentioned the green things that look like curves are the zero width surfaces.
Rhino does recognize four of them as BadObjects but only after they are extracted from the original polysurface.
