Possible bug with BooleanDifference method
I had a project come to my attention where a script involving BooleanDifference was working fine in V5, but failing in V6. I cut out the fat, and have a sample that I can post here:
boolean issue.3dm (197.4 KB)
and here is the simple little script to try:
def BooleanDiffTest():
    obj1 = rs.GetObject("Select the surface")
    if obj1:
        obj2 = rs.GetObject("Select the cylinder")
        if obj2:
            newObj = rs.BooleanDifference(obj1, obj2)
Notice the small hole on the left surface. I’ve narrowed it down to that as the cause of the failure. Test the script above on the right surface and it works.
Here is a short video showing the problem:
(Dale Fugier) #2
Got it, thanks @DanBayn
– Dale
Thanks Dale. BTW, I don’t have permission to view the log.
(Dale Fugier) #4
Try again…
