Hi
I have an error and I can’t work out what I’m doing wrong. I have two surfaces and I am trying to calculate the angle between them so that they can be folded for fabrication (sheet metal).
In Grasshopper I get the normals to the surface and calculate the angle. The reflex angle is 265 deg.
However, in Rhino when I measure it using Crease Angle Dimension and/or Angle Two Objects, it returns 275 deg.
I am assuming the discrepancy has something to do with the plane in which the angle is being calculated but I can’t work it out.
Any ideas?
