really nice, i just wished it would have a very very slight bump definition in the reflection of the metal, its a bit too glossy.
also some coffee in the cup would look inviting. but nevermind my comments, good work
Grazie buone cose
Hi Anghelos,
I have to reply just because of my own photo on my profile I make coffe on it every day.
I am sure I could not create what you have created!
From a security standpoint I believe that your safety valve is a bit too high :-)… But as you are not making any coffee, this is not a problem
BR,
Jens
OK now I’ll check my moka again
Thank you for the note, I can assure you that I own a stainless steel moka with a valve at the same height.
However it is not a problem to correct, it is a 3d image
Good things
Angelo
Excuse me in what sense you could not create what I created.
Hi Anghelos,
Sorry about the valve - mine is a Bialetti and the valve serves another function: Maximum fill height is just below the valve - your maximum fill height could be determined otherwise. Or maybe some other property makes it different. It just caught my eye and I jumped to conclusions.
Re the creation: I do not have your skills - so hats off to you!
very nicely done- thanks for sharing!
A lovely and real work!
Well done!
Thank you
Good things
Thank you
Good things.
OK thanks for the information.
I don’t think you can’t create quality 3d objects, I also learned and like you I thought I would never be able to.
Then with effort I got some good results believe me.
Good things
Rhino render or?
Very nice!!
Grazie.
Rendering in Keyshot
And now I can smell coffee
I need to go and make a coffee now
Thank you for commenting
Good things
