C# scripts (Mac) - undo not working
V8 on a mac intel (Version 8 (8.12.24261.13002, 2024-09-17))
…a simple c# script using RhinoCode that adds some geometry to the doc.
cmd-Z is not working after the script has run.
that s not very handy.
@eirannejad ?
kind regards - tom
hi @Tom_P This bug has been (hopefully) fixed
RH-83835 Undo stops working
Pls let me know if your case is different.
I can send you a newer build with that fix, if needed.
run this fantastic script:
using System;
using Rhino;
RhinoDoc.ActiveDoc.Objects.AddPoint(1,2,3);
_selLast
1 point added to selection.
_undo
Nothing to undo.
i would expect that running the script is part of the undo-stack and the point vanishes…
if a newer build for mac intel does not have this issue - i am happy to use it.
thanks.
tom
Undo seems to work after running that code
pm sent
Thanks - the Problem is solved with your private message early bird dujour Version 8 (8.13.24267.06002, 2024-09-23).
