C# script - use Command-Class - best practice
// #! csharp
using System;
using Rhino;
using Rhino.Commands;
using Rhino.Geometry;
using Rhino.Input;
using Rhino.Input.Custom;
using Rhino.DocObjects;
public class AddLineCommand : Command
    public override string EnglishName => "AddLineExample";
        // Prompt for the first point
        Point3d point1;
        var point1Result = RhinoGet.GetPoint("Select first point", true, out point1);
        if (point1Result != Result.Success)
            return Result.Cancel;
        // Prompt for the second point
        Point3d point2;
        var point2Result = RhinoGet.GetPoint("Select second point", true, out point2);
        if (point2Result != Result.Success)
        // Create a line from the two points
        Line line = new Line(point1, point2);
        // Add the line to the document
        doc.Objects.AddLine(line);
        doc.Views.Redraw(); // Redraw the view to show the line
        // Return success
        return Result.Success;
    public Result RunCommandFromScript()
        return RunCommand(RhinoDoc.ActiveDoc,RunMode.Interactive);
var myCommand = new AddLineCommand();
var result = myCommand.RunCommandFromScript();
how do you test small code snippets ?
In former Times I had a huge “testStuffPlug-in”.
but I like the power of c# scripts:
I started to add / use a public “RunCommandFromScript” Function that can call the protected RunCommand Method.
Initializing an Instance of AddLineCommand and call RunCommandFromScript are just 2 lines that make the hole command function without any plug-in architecture / loading / …
Does this approach violate against anything ?
Do I miss something ? are there nicer approaches to have working code fragments - that might be used later …
thanks for your ideas / comments / notes
kind regards - tom
If you are writing a C# script, you can simply write the command logic in the global scope of the script and run it in the script editor. This script can later be added to a project and published as a Rhino plugin
// #! csharp
using System;
using Rhino;
using Rhino.Input;
RhinoDoc doc = __rhino_doc__;
Point3d point1;
if (Result.Success == point1Result)
    Point3d point2;
    if (Result.Success == point2Result)
        doc.Views.Redraw(); // Redraw the view to show the lineĂŹ
thanks @eirannejad for having a look.
i wanted a fast method to take some samples for example from dale’ s github and get them running.
for example this.
extend them
with 4 lines to get them running and see if it fits for my problem…
then go on with my complex c# project in visual studio…
does this make sense ?
kind regards -tom
It does. The fastest way is to build the visual studio solution and load the plugins in Rhino to test the commands.
one more question: the c# scripts in script editor - each script runs in its own scope ?
let s say i want to have one script that starts an display conduit, and another that disables it. how to set up a scenario for development like this in script-Editor ?
thanks
tom
For that the proper way to do it is to create a C# dll (shared library) that both scripts can reference and access the shared functionality.
A quick and dirty way of doing this (that is similar to using scriptcontext.sticky dictionary is to use the data dictionary that is available on AppDomain in dotnet
First script that sets up the shared api instance:
// #! csharp
using System;
using System.Reflection;
public class SharedAPI
    public void DoSomething()
        Rhino.RhinoApp.WriteLine("It Works!");
var myapi = new SharedAPI();
AppDomain.CurrentDomain.SetData("my-api", myapi);
Consumer script that gains access to the shared api and calls a method on it
// #! csharp
using System;
if (AppDomain.CurrentDomain.GetData("my-api") is object apiObject)
    dynamic api = apiObject;
    api.DoSomething();
consumer.cs (179 Bytes)
shared.cs (247 Bytes)
thanks.
what s the advantage of this pattern instead of adding an Object to
RhinoDoc.ActiveDoc.RuntimeData
I have another problem with (un) subscribing Rhino.Idle Event …
do I miss something or is this the amount of complexity where a full plug-in in Visual Studio is the better choice ?
No particular advantage. Use whichever that works. It’s basically a global place to hold on to a value so both scripts can look it up.
A good practice is to subscribe and unsubscribe from events, in the same script. If you find that this is making things too complicated, then yes, a Rhino plugin would be a better choice.
ok - thanks again.
if i want to access the same class definition / casting in several c# scripts - is that possible ?
this would allow to skip
… back at visual studio with a demo-Plugin, because of the event handling and display conduit stuff:
did not find a nice approach to do it in the script editor AND produce code that is compatible with later plugin-Development … what I was hoping for.
It is possible but you’d need to create a script editor project and add the shared code as a library. However this is meant to be an easy way to share scripts. If you are expecting to have advanced features it is still probably better to use Visual Studio.
See these pages
Create Projects
Add Library to Project
