I am trying to make a simple command in rhino to array rectangles in a curve, the problem is the commandline options does not work properly as an input. This is just a test I am trying to learn C# in VS.
int i;
var selectedcurves = new CurveList();
Point3d[] divptarray;
//Step 1 - Select curves---------------------------------------------------
GetObject gp = new GetObject();
gp.SetCommandPrompt("Select some curves");
gp.GeometryFilter = ObjectType.Curve;
RhinoApp.WriteLine("Now Choose the Options");
// set up the options
OptionInteger intOption = new OptionInteger(1, 1, 99);
OptionDouble dblOption = new OptionDouble(2.2, 0, 99.9);
OptionDouble dblOption2 = new OptionDouble(2.2, 0, 99.9);
gp.AddOptionInteger("Division", ref intOption);
gp.AddOptionDouble("x", ref dblOption);
gp.AddOptionDouble("y", ref dblOption2);
int divisions = intOption.CurrentValue;
double Xrec = dblOption.CurrentValue;
double Yrec = dblOption2.CurrentValue;
while (true)
// perform the get operation. This will prompt the user to input a point, but also
// allow for command line options defined above
GetResult get_rc = gp.Get();
if (gp.CommandResult() != Result.Success)
return gp.CommandResult();
if (get_rc == GetResult.Point)
doc.Objects.AddPoint(gp.Point());
doc.Views.Redraw();
Rhino.RhinoApp.WriteLine("Command line option values are");
Rhino.RhinoApp.WriteLine(" Integer = {0}", intOption.CurrentValue);
Rhino.RhinoApp.WriteLine(" Double = {0}", dblOption.CurrentValue);
Rhino.RhinoApp.WriteLine(" Boolean = {0}", dblOption2.CurrentValue);
else if (get_rc == GetResult.Option)
continue;
break;
var curve = gp.Object(0).Curve();
double[] parameters = curve.DivideByCount(divisions, true, out divptarray);
myFunctions.XDrawPoints(divptarray, doc);
myFunctions.XDrawRectanglesInCurve(divptarray, curve, Xrec, Yrec, doc);
doc.Views.Redraw();
return Result.Success;
, many thanks !!
