C-planes and Views
When I change C-plane, I use change to object, it changes all the views (left, right, front, back, perspective) according to the new C-plane. Is there any way to keep the views unchanged, only the C-plane changes, not the views?
Thanks!
In Options>Modeling Aids, you probably have “Universal construction planes” checked. Check “Standard construction planes” instead and you should get the behavior you want.
–Mitch
Mitch, you are the best!
