i have problem with panel made with c# i used example @dale shared somewhere here and used just for checking his guid for panel then changed to new guid but rhino now shows 2 options listed when right clicking for choosing prop tabs. Is there anyway to unregister from rhino previous guid?
When i delete plugin from rhino both options from listing disappears. I tried to rebuild but without luck - panel is still listed twice. I could try to create another guid for this panel and check if it will list it as 3rd option - but i dont want to make mess inside my properties tabs listing.
I don’t think we have docking panel samples that how how to use a fancy control. But if you are using WinForms, then you can use a ListView control to display a grid. I believe the collapsing stuff is our own custom stuff.
firstly: are there any c# samples for v5 still available? i see on git that all stuff is updated for v6 already.
secondly: i dont want anything fancy i just want to match native rhino ui for seamless experience i just need collapisible sections, sliders and tables etc. like in attachment - i thought it would be good if plugin will have same look like rhino ui for integrated (like built-in) feel.
