C# - Manipulating Selected Mesh Vertices
Ok, so I’ve tried to access selected Mesh vertices (selected using SelBrushPoints) but the IsSelected status doesn’t seem to be valid. I get no result from the following code despite the vertices being selected in the Rhino Viewport:
// Check if grips (control points) are enabled for this mesh
            if (!rhinoObj.GripsOn)
                RhinoApp.WriteLine("Error #3 - No grips");
            else
                var grips = rhinoObj.GetGrips();
                if (grips != null && grips.Length > 0)
                    for (int i = 0; i < grips.Length; i++)
                        if (grips\[i\].ComponentStatus.IsSelected) // Check if this grip is selected
                            selectedPoints.Add(grips\[i\].CurrentLocation); // The Point3d position
                            selectedIndices.Add(grips\[i\].Index); // The index in mesh.Vertices
Any hints about how to access the already selected Mesh vertices?
//Rolf
ComponentStatus.IsSelected doesn’t work for checking grip selection.
Use IsSelected() on the grip instead.
foreach(var grip in grips)
    if(grip.IsSelected(false) == 2)
        selectedPoints.Add(grip.CurrentLocation);
Thank you, that worked well!
