How do I choose currently selected vertex number in C# GetObject ?
I have something like this:
var vert = go.Object(0).Mesh().Vertices[0];
And the 0 in the Vertices[0] is because I don’t know how to get currently selected vertex.
You need to access the GeometryComponentIndex on the ObjRef retrieved from go.Object(0)
ObjRef obj = go.Object(0);
Mesh m = obj.Mesh();
ComponentIndex ci = obj.GeometryComponentIndex;
if(ci.ComponentIndexType == ComponentIndexType.MeshVertex)
int vi = ci.Index;
var vertex = m.Vertices[vi];
else if (ci.ComponentIndexType == ComponentIndexType.MeshTopologyVertex)
int ti = ci.Index;
var vertex = m.TopologyVertices[ti];
else
// not a mesh or topology vertex selected - fail
Thanks for the answer.
One more question, I was able to get topologyVertices from my mesh, bu mesh.Vertices.SetVertex(vi, translationPoint); takes Vertices, so how do I find relation between topologyVertices and Vertices?
To make clear what I’m trying to do I will put my code:
public Result MoveVertices(RhinoDoc doc)
GetObject go = new GetObject();
go.GeometryFilter = ObjectType.MeshVertex;
go.Get();
if (go.CommandResult() != Result.Success)
return go.CommandResult();
if (obj == null)
return Result.Failure;
Mesh mesh = obj.Mesh();
if (mesh == null)
int vi = ci.Index;
var vertex = mesh.TopologyVertices[vi];
var v = mesh.Vertices[vi];
if (vertex == null)
GetPoint gp = new GetPoint();
gp.SetBasePoint(vertex, true);
gp.DrawLineFromPoint(vertex, true);
gp.Get();
if (gp.CommandResult() == Result.Failure)
return gp.CommandResult();
var translationPoint = gp.Point();
Mesh duplicate_mesh = new Mesh();
duplicate_mesh.CopyFrom(mesh);
duplicate_mesh.Compact();
if (duplicate_mesh.IsValid == true)
doc.Objects.Replace(obj.ObjectId, duplicate_mesh);
doc.Views.Redraw();
return Result.Success;
OK, I see the problem, looks like it will be a bit more difficult than I thought, as I will actually need to move not one, but multiple vertices at once, as from what I think, one topology vertex may contain multiple vertices.
Use the Item property to set all vertices associated with the topology index.
int topologyIndex = ci.Index;
int[] vertexIndices = mesh.TopologyVertices.Item[topologyIndex] = translationPoint;
Yup menno, many thanks for help, finally it will go like this:
int[] vertexIndices = mesh.TopologyVertices.MeshVertexIndices(topologyIndex);
Maybe anyone will find it useful:
go.Get();
if (obj == null)
if (mesh == null)
var vertex = mesh.TopologyVertices[topologyIndex];
if (vertex == null | vertexIndices == null)
gp.Get();
var endPoint = gp.Point();
var translationVector = endPoint - vertex;
foreach (var singleVertex in vertexIndices)
mesh.Vertices.SetVertex(singleVertex, endPoint);
doc.Views.Redraw();
