How do I get a list over selected grips on a mesh using C#?
In Python this works : selectedList = rs.SelectedObjectGrips(mesh_id)
How do I do this in C#?
Regards
Ove
Regards
Ove
You can look at the source of the function to see how it’s done:
Starting in line 325
Thank you Lando,
But I have a Python script that works, but I want to do this in C#.
What is the equivalent of
using RhinoCommon and C#.
Regards
Ove
Yes, the source code shows you what rhinocommon methods are used to get the behaviour of rs.SelectedObjectGrips. If you can’t translate python to C# I can do it for you. Maybe try it first and post here if you get stuck
Thank you Lando,
Your document have a lot of interesting functions, so I wish I was able to convert them to C#.
If you could post the C# code for UnselectObjectGrips - ( the last function) it sure will be a great help.
To my original problem - list selected grips - I made this function:
GripObject[] arrGrips = obj.GetGrips();
if (arrGrips == null || arrGrips.Length == 0)
return Result.Failure;
Global.lstGrpIndex.Clear();
foreach (GripObject grip in arrGrips)
if (grip.IsSelected(true) == 2)
Global.lstGrpIndex.Add(grip.Index);
All advice and improvements are received with thanks!
Regards
Ove
Yes can do, I’m on vacation right now so it will take some time before I’m touching a computer again though
