I’m rather new to python and rhino scripting, please bear with me.
I want to let the user select and move any type of object including grip in a certain direction, using python. I figured that rs.GetObjects ignores grips, so I’m doing the objects input like this :
Where 2013524799 is a bitwise OR of all the geometry filters.
So in objs I successfully have any type of objects including grips. I want to translate each of these objects, but if I move them like this :
for obj in objs:
rs.MoveObject( obj, vector )
points, curves and surfaces are moved properly but grips are ignored. What is the reason for that ? Is there anything I can do using rhinoscriptsyntax ? It would have been a breeze…
Digging for a workaround I’ve read this related post from Dale Fugier. However I had a rough time with this solution, because I want to move the grips and redraw at runtime. scriptcontext.doc.Objects.GripUpdate will update the grip, but either I set its deleteOriginal argument to False and the objects are duplicated many times along the translation, either I set it to True, and nothing happen, I assume because the grip is removed from the TransformObjectList. I tried to add the new object returned by GripUpdate to the TransformObjectList, but it doesn’t seem to work.
Is there an easier solution to move grips at runtime with python ? If not I will revert to trying to adapt @dale solution, but I’s been a few hours I struggled with this already…
By “at runtime” I mean that I want the grips to move while the user is picking an end point for the translation, and the geometry updated progressively.
I wanted to code a set of functions to transform objects parallel to the target plane ( pan parallel to the target plane, rotate parallel to the target plane… ). This to make easier the editing of geometries in perspective view. I finally solved my problem with this function :
def panObjs( newPoint ):
global startPoint
# move non-grip objects
for obj in objs:
rs.MoveObject( obj, newPoint - startPoint )
# move grip objects
for grip in grips:
gripObj = sc.doc.Objects.Find( grip )
if gripObj:
gripObj.Move( newPoint - startPoint )
# get list of selected grip owners
owners = []
for grip in grips:
if gripObj:
owners.append( gripObj.OwnerId )
# remove duplicates from owners
owners = list( set( owners ) )
# update owners
for ownerId in owners:
ownerObj = sc.doc.Objects.Find( ownerId )
ownerGrips = ownerObj.GetGrips()
indexes = [] # grip indexes under update
for ownerGrip in ownerGrips:
if ownerGrip.Id in grips:
indexes.append( ownerGrip.Index )
grips.remove( ownerGrip.Id )
newOwner = sc.doc.Objects.GripUpdate( ownerObj, True )
ownerObj = newOwner or ownerObj
newGrips = ownerObj.GetGrips()
for index in indexes:
grips.append( newGrips[ index ].Id )
startPoint = newPoint
I call this in a custom Rhino.Input.Custom.GetPoint.OnDynamicDraw. I don’t know if it’s optimal, and it doesn’t seem to handle SubD geometries.
