I created an add-ins.
i wannt make shortcut button click
someone help me~!
i use c#
I am not sure we understand what this means. Are you using WinForms? Are you just trying to hook up a button click event?
I’m sorry I’m not good at English.
I have to click on the button to execute the command
I want to use the command to execute a button click event
I wonder if you can run each button with a shortcut
If you want to run a command when you click a button, then have the button’s click handler call RhinoApp.RunScript.
– Dale
