I´ve now been able to repeat it, sometimes the command line justs repeats the last _SelNone. If i remove it at the end of the macro and leave the first _SelNone where it is it does not fail. (V4 SR9). You might also check this out, it did not fail a single time:
Trying to update this Macro with also setting the “Continue=Yes” but can’t seem to get the macro to work. Feel like I Should be getting this at this point, but keep running into these little probs
