i am wanting to build some elements only and the length of it should be between 500-600mm can someone help me please?
Anleimer aufteilen Support.gh (20.0 KB)
I opened your definition, but was not able to understand what exactly you need. Not sure why you need to “Shatter” the curves for (BTW, inputs for your Shatter component don’t match).
The resulting small panels seem to be working. What is the result you are after (model manually in Rhino and post here to compare, or sketch and point out what is wrong).
Thank you for your help, but i get it on my own
