Hi there ![]()
Just wondering if it’s possible to build multiple geometries onto the layers of the geometry which was used to build the new geometry?
See pic for explanation
Regards
Hello - in general new geometry appears on the current layer, so to do something different, you’ll need a script.
Hi Pascal, thanks for your reply
Just wondering if there could be a toggle option within the command line options so the user can specify how they want the result?
I believe the results are similar for other commands that build new geometry from existing ones.
-Jeremy
