Bugs WIP 02.03
  1. Rebuild dialog
    When entering Point Count, the Degree value changes by itself.
    If I’m trying to rebuild a degree 5 curve and start typing, say, 10 points, the Degree automatically drops down to Degree 1.
  2. .3dmbak files
    In Rhino Options > Files > Save, I turned off .3dmbak, but Rhino still saves the backup file in the model folder.
Hei Ja -
I’ve put that on the list: RH-92149 File IO: 3dmbak Files Always Created
@Ja-Ka thanks for reporting.
That is an unfortunate side effect of applying the changes immediately. The 1 you type is applied right away. I’ll get this tuned up
RH-92150 Rebuild applies changes too quickly
this will be fixed in the next WIP.
ps: Also the input span count, which didn’t make it into this week’s WIP will then be included
RH-92150 is fixed in Rhino WIP
