[BUG?] ZoomSelected not working on curves inside Detail View
Steps to reproduce:
  • open a new file in v7
  • add some curves on the XY plane
  • create a new layout with 1 detail
  • make the layout + detail active
  • zoom out inside the detail, select some curves and run ‘ZoomSelected’
Actual behaviour:
Following message is displayed in console: ‘Unable to zoom - no objects are selected.’
Expected behaviour:
The zoom should detail view space with the selected objects. ZoomSelected on other geometries seems to work fine (Surfaces, BREPs…).
Also tested in v6 and working as expected.
Version info:
Rhino 7 SR6 2021-5-4 (Rhino 7, 7.6.21124.09001, Git hash:master @ 1a9a92254a9f347268c4c9c7f2dec50bcd90215e)
License type: Commercial, build 2021-05-04
Hello - I see this, thanks.
RH-64108 Zoom Selected: fails in a detail view
Same problem with Rhino 7, 7.6.21127.19001, Build 2021-05-07.
Some curves are _Zoom _Selected-able, some are not and sometimes previously Zoomable curves become inactive.
Hi Kevin -
That’s correct, item RH-64108 is still open.
