Hello!
When I activate a Detail, I cannot select objects, only some. Nothing is locked, and any object can be selected in the model space. However, it’s possible to CTRL-A select all in the Detail.
It’s maybe a regression, because I think this occurs only since lately.
Thanks for looking into this!
Hi Eugen - is there any difference between the objects that can and cannot be selected? (Text or dimensions for example) Can you post a simple example?
Thanks, Pascal!
There’s no obvious difference between the objects. A few curves in the same plane, none is selectable except one.
It might have to do with VisualArq. There’s a level section active.
This does not help much, I know. Will test further.
Best regards
