BUG: Wrong volume fx
wrong volume.3dm (169.3 KB)
definitly not zero:
Hello - I see that - so far I cannot reproduce it…
fun fact is that other solid gives correct results… maybe under 1m3 it makes problem?
A new leader also works, here - does that work ?
yes new leader works… even if i paste the same content from not working one
Hi @ivan.galik,
Your model’s unit system is in Millimeters but the leader’s unit system is Meters.
– Dale
Hi Dale - But the box is big enough to register non-zero volume in meters. A new leader, asking for meters on the same box looks correct (right?)
Changing the leader from Standard to another annotation style (Millimeters Large) shows the correct volume.
Yes, good catch - it looks like maybe the fX conversion is not taking that into account.
RH-67437 Text fields- Volume - ignores dimstyle units
RH-67437 is fixed in Rhino WIP
