Fbx units export in CM regardless
I just found out that an FBX file exported and imported back in Rhino, reports a difference in Units.
The Rhino file is in mm and the re-imported FBX is in cm.
It seems however that the scale is off by a factor of 10. Is this expected or a bug in the exporter?
test.3dm (16.7 KB) test.fbx.zip (3.9 KB)
Thanks
-Willem
Hi Willem- thanks, I see that.
http://mcneel.myjetbrains.com/youtrack/issue/RH-26511
(not visible to the public, yet, but it seems like it might actually happen)
