Bug: ViewCapturetoFile yields no output when a clipping plane is enabled
The ViewCapturetoFile Command doesn’t output any image when a clipping plane is enabled for the view. The command log states an image is succesfully saved however.
When a clipping plane is not present ViewCapturetoFile functions normally. I am using Rhino 7, 7.12.21313.06341
Hi Bart - that works here in the latest -
I would update to the most recent service release and try that -
https://www.rhino3d.com/download/rhino-for-windows/7/latest
If that does not help, please run SystemInfo in Rhino and copy/paste the results here.
Hi Pascal,
Thank you, I have downloaded the newest version and will test this shortly.
-Bart
Thank you Pascal, I have tested it and it now works.
Kind regards,
Bart
