Bug: VA properties panel becomes blank
Hello!
After a while, this happens (with any VA part):
The only thing that helps is restarting Rhino.
Rhino 8.23.25232.17001
VA 3.5.0.20135
Thanks!
@eugen I cannot reproduce this error. If you click outside the properties panel (any point in the model view), and select the slab again, do the properties show up?
Have you noticed any pattern when this error occurs?
Hi! Can’t tell yet - I’ll keep watching.
Here’s another thing that could be related: the VA properties panel is somehow not well embedded into that Rhino panel container (what’s the correct name).
You can see that the content overlaps the vertical separator line a bit, and it is not possible to grab the separator for resizing the panel. Only when you move the scrollbar at the bottom to the right can you grab the separator, and still, there are some artifacts visible:
Looks like your panels are still not ported to ETO, supporting dark mode:
I’m guessing, but if you would, I think all those problems would be solved, too. Looks like the mix of old and new UI libraries is causing problems.
Btw., I use a 4k display.
Thanks!
Hi @Eugen excuse the late reply on this issue. This seems to happen when the properties panel is too narrow. You can stretch it by grabbing it from the line separator at the top part, where the icons for the different panels are located:
PD1: I’m not sure if this issue has to do with the first one, but we will study both.
PD2: Dark mode support is something pending to be added.
