Hi!
It was very easy to use in Rhino 6 the function “Apply Edge Softening”: we only had to go to the render window, and then, click on the icon “Apply Edge Softening”, and define the softeness. Now, the window and the way to do this has changed: first, we have to select the mesh, after, tape Enter, and then, at the right corner, a new windows opens, where we have to put “Activé” to do the function, and after, we have to say “forcer l’adoucissement”. This is more complicated that in the version 6 of Rhino, but, the worst is that i can do this, everytimes, at this moment, my Rhino crashes, and i have a good computer.
Can you please explain me why, and we we have to do against this?
Thanks so much!
Please run the Rhino SystemInfo command and post the results, so we can see the counter resources Rhino is detecting.
Thanks
Hi
Thanks
This is this:
Rhino 7 SR11 2021-10-12 (Rhino 7, 7.11.21285.13001, Git hash:master @ ca75d3c67ded62b7ad8856f48d5ef2d6d1d926be)
License type: Commerciale, version 2021-10-12
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 11-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.51
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2020
Driver Version: 27.21.14.5751
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.11.21285.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21285.13001
In Options > Plug-ins, disable V-Ray and restart Rhino.
Any better?
Hi
No, i just come to disable Vray, and then, restart Rhino, and when i click on “Activé” for the command “Apply Edge Softening”, then, it tooks a lot of time searching, and then, the screen is white like a crash or a beug…
Hello- is this true in any file, or just some? Can you make it work properly in a new file with just a box?
(Running the command should not bring up any panel or dialog, all the settings should be at the command line.)
Hi Pascal, with only a box it is ok.
I am afraid my meshes files is very complex, and i have to find how to do that the meshes has less complexity in Rhino…
You may have bad meshes or bad objects. I would check them with the following commands: ShowEdges, Check, SelOpenPolysrf, SelSrf, SelBadObjects, ExtractBadSrf.
MeshRepair and RebuildMesh commands may be used to repair bad meshes. If the meshes are very complex, you may have to use different program than Rhino to repair them.
Meshmixer and MeshLab are free mesh cleaners and mesh editors. They are equally popular. MeshLab has more features, but it is more buggy.
CloudCompare is free point cloud and mesh editor.
download: http://www.danielgm.net/cc/release/
short video: https://www.youtube.com/watch?v=BbqC_0vuED8
TopoGun mesh editor ($100) is fast. video: TopoGun - Introduction on Vimeo
Geomagic ($8,000 to $30,000) and PolyWorks ($10,000 to $30,000) can import gigabyte-size meshes.
VirtualGrid VRMesh ($695) can also handle large meshes.
Hi -
I suppose that could simply indicate that Rhino is very busy working on it. When you check the Rhino process in the Windows Task Manager, is it still working?
Hi Andrew, thanks so much! I will check to this!
Hi Wim, i will try this, but i tried waiting around five minutes, so, i am afraid there is a bug!
Hi -
The only way we can check this is if you post the file and steps to reproduce.
Hi Wim
Thanks so much
Here you have the file ![]()
04RHINO Voronio Lampe_PourSTL.3dm (8.1 MB)
Hello- thanks, I am looking at it now… I see a lag as well, even after some mesh cleanup.
@kostaldeak - you can try:
RebuildMesh-
Weldat say 45 degrees - Select the mesh, set softening at .25 and apply (at .5 it will not do it)
You will need to wait, but it gets there. I do not know if this delay is expected, in the current state of things – I seldom use edge softening on meshes (as disitinct from polysurfaces) myself but I’ll ask the developers.
Hi Pascal, thanks so much!
Sandrine
