Rhino 7 Service Release Candidate Available
Rhino 7 SR3 Release Candidate 1 for Windows and Mac (7.3.21012) is now available
Bugs Fixed:
  • 3DFace:
    • Tooltip for Persistent On Mesh quits after initial pick (RH-58879)
    • Results in unwelded mesh edges when using mesh constraints (RH-62113)
  • ClippingPlane: Scaling up causes flipping trouble (RH-61225)
  • CrvSeam: Seams located incorrectly when working with multiple curves (RH-62009)
  • ExtractSrf: Count is wrong (RH-62083)
  • File IO: PDF Export - Preview scaling issue (RH-62035)
  • Grasshopper: Timers expire too often (RH-62138)
  • Gumball:
    • Extruding a polyline with scale handle creates degenerated faces (RH-15101)
    • Extruding does not select the end edges in Shaded mode (RH-61985)
    • Sub-object selection unexpectedly transfer to history children (RH-62049)
  • Paste: Lags in V7 (RH-60569)
  • Print: Vector output does not pay attention to Picture material transparency (RH-60275)
  • Rendering: Materials: Importing rmtl files adds many placeholder items to Type list (RH-62055)
  • Revolve: Deformable option may displace the surface (RH-62045)
  • RibbonOffset: Fails to generate offset curve on outside (RH-61854)
  • SDK: RhinoCommon: Line.ToNurbsCurve() not setting domain (RH-61974)
  • Surface-surface intersection: Incomplete intersections (RH-61958)
  • Tab Constraint: Is canceled when base point is picked and rejected (RH-38345)
  • Toolbar: "Solid Tools" toolbar has two "Unjoin Edge" buttons (RH-62114)
  • UVEditor:
    • UV meshes messed up from OBJ (RH-23995)
    • Fails with degenerated single mesh face (RH-62127)
  • Unwrap:
    • Creates separate UV meshes until edges are rebuilt (RH-38531)
    • Not all selected seams uncouple faces correctly (RH-42696)
    • Fails to use selected seams (RH-43792)
    • Fails on a surface (RH-62000)
Cosmetics:
  • Options: Update frequency changed to use drop-down menu instead of combo box (RH-62097)
Enhancements:
  • File IO: PDF Import - Supports layer hierarchy (RH-61109)
  • Polyline: Tab constraint now suspends Helpers (RH-62149)
  • Sketch: Added ClickToSketch option (RH-32560)
  • Splash and About: Allow Esc to close (RH-61847)
  • SubDSweep: /SubDSweep2: New SubDChain option (RH-61779)
Features Added:
  • Zoom: Scrolling mouse wheel with Ctrl/CMD keeps focus on view center (RH-62003)
Regressions Fixed:
  • BoxEdit: Does not work with sub-objects (RH-61960)
UI Change:
  • Toolbar: Tidy up SubD Tools toolbar (RH-62115)
Mac-Only Changes
Bugs Fixed:
  • Display: Apple Silicon reports 0 VRAM which causes crashes in Rhino (RH-62061)
  • Export: Options are not visible from layout page unless dialog is resized (RH-61670)
  • Libraries: Does not download localized contents when version.txt is deleted (RH-61427)
  • MoveFace: Viewport doesn't get focus during command for Osnaps (RH-61085)
  • Rendering: Materials: 'Assign to Layers' incorrectly shows layers that have been deleted (RH-61929)
  • Sketch: In progress sketch previews disappear. (RH-62157)
Crashes Fixed:
  • Export: Export Selected from File menu crashes Rhino on Mac (RH-62076)
Enhancements:
  • File IO: AI Export - Allows more digit places in scale values (RH-62117)
Windows-Only Changes
Bugs Fixed:
  • File IO: PDF Export - Preview doesn't show dimensions (RH-62040)
  • Properties: Annotation Style is blank (RH-61560)
  • Revolve: Fails with SubD edges as input (RH-61983)
  • SDK: Rhino.AddLoftSrf broken in Rhino 7 SR0 (RH-61984)
  • SDK: RhinoScript: Creating Rhino.Interface.7 always launching new instance (RH-62126)
